Verfasst am: Mi, 26.01.2005 08:05 Titel: Wetter-Anzeiger |
http://amigazeux.net/wetter Wetter ist ein Anzeige-Client für Wetterdaten, die von http://www.wunderground.com/ bezogen werden.
Zitat: | Wetter should run on any Amiga or emulated Amiga. AmigaZeux recommend you upgrade to MorphOS though (well, we would, wouldn't we?), as this is the OS it has been developed and most thoroughly tested on.
We do not support Hyperion's OS4. However, it should work on OS4 all the same. But if it doesn't, it's because OS4's legacy emulation isn't up to scratch, not because we added anti-OS4 code. Remember that.
Your machine must have, at very least:
An internet connection
A TCP/IP stack
A working install of MUI3.8 or higher
MorphOS 1.4 or higher (AmigaO 3.x should also work)
Recommended system:
MorphOS and Pegasos
A permanent, fixed-rate internet connection
GFX card with 16 bit colour or better
MUI 3.9+ |
_________________ ------------------------------
