Bugfix für TCP/IP-Stacks AmiTCP/Genesis
BeitragVerfasst am: Sa, 26.03.2005 09:00    Titel: Bugfix für TCP/IP-Stacks AmiTCP/Genesis Antworten mit Zitat
Link: http://www.aminet.net/package.php?package=comm/tcp/AmiTCP_PacketFix.lha
Zitat:
This is an unofficial patch for AmiTCP/Genesis which fixes a bug in the
packet fragmentation code during sending, which fragments tiny packets
when unnecessary.
In particular, when using AmiSSL v2 (IBrowse), some secure sites and
servers cannot cope with these tiny split packets, resulting in the
infamous SSL connect errors in IBrowse. With the fix installed, the
errors will be solved and SSL v2 and v3 support can be both be safely
enabled in IBrowse.
powered by
