SView 5 - neue Versionen
BeitragVerfasst am: Mo, 21.03.2005 08:05    Titel: SView 5 - neue Versionen Antworten mit Zitat
Das Grafikverarbeitungspaket Superview ist jedem Amiganer wohl ein Begriff. Mittlerweile gibt es diesen Klassiker auch für lau im Aminet!
Zitat:
What is the SView5 package actually ?
It does consist of a huge object-oriented module set
called "SView5-Library", that consists of many classes for
loading/saving (SV5Objects), processing (SV5Operators)
and rtg-displaying (SV5Drivers) graphics. These are
dynamically loaded and flushed, depending on the free
amount of memory - under the case, there are not many
similarities to OS 3.x datatypes.
There are several programs included:
- SView5: the powerful main program that allows to access all
options and settings, allows to load, save, process
and convert images - not only via the GUI but
also using ARexx and so on.
Includes a RTG-compliant screen-grabber!
- BatchProcess Batch conversion tool, for applying upto 4 image
processing operaters to a number of graphics by
wildcards and save them in a different file format,
e.g. load a bunch of JPEGs, then resize, dither
and save them as PNG files.
- PNG-Box5, dedicated tools for creation of graphics for
JPEG-Box5, WWW usage (HTML pages) with progressive/interlacing
GIF-Box5: and transparency support
- WinSlide: for viewing images in a window on public screens,
using as few memory as possible - smooth scrolling
inclusive! Supports 8 through 24 bit displays.
- ScrollSlide: like WinSlide but using its own screen,
for best colors even on 8 bit displays
- CyberSlide: like viewing images from SView5 using a CyberGfx
SV5Driver with 16/24 bit capability, but implemented
as small standalone program
- SuperSlide: like CyberSlide but for AGA screens and screen modes,
additionally dithering is done when necessary
- SVPrefs: for changing settings of SView5-Library modules
easily.
Most people forget about WinSlide and the other tools, even when
already been using the program for some time. So, don't forget
to check them out when testing :-)
There's also a huge difference between SView5 and the
SView Productivity Suite I + II CD-ROMs - as described on
their covers or at www.schatztruhe.de
SView5/-Library is NOT compatible with SViewIV and its predecessors,
it also is NOT compatible with previous versions of the library
and its sub-modules.
Keyfiles of predecessors won't work with any of the included tools.
OS 3.1 or greater is REQUIRED!
Link: http://www.amiga-news.de/de/news/AN-2005-03-00083-DE.html
legale Key-Files und Zubehör gibt es natürlich auch!
Link: http://www.aminet.net/search.php?query=sview
BeitragVerfasst am: Di, 13.02.2007 19:06    Titel: Antworten mit Zitat
Zitat:
Andreas Kleinert stellt ein Update seines Bildbearbeitungs-Programms SView5 zur Verfügung. SView steht für AmigaOS 3 und MorphOS zur Verfügung, unterstützt über 100 Grafikformate und ist speziell für das automatisierte Bearbeiten bzw. Konvertieren großer Bildermengen gedacht.
Link: http://www.ar-kleinert.de/download.html
huepper
Anmeldedatum: 05.11.2004
BeitragVerfasst am: Di, 13.02.2007 22:07    Titel: Antworten mit Zitat
Gerade vor einigen Tagen hab ich ihm noch für seine Arbeit an SView5 und den Datatypes gedankt und nu gibts schon wieder eine neue Version von SView5.
Hilft das doch etwas, wenn man einem Programmierer mal einfach seinen Dank ausdrückt ? Smile
Ach hier nochmal was für die, welche keine Kommentare auf a-news.de lesen:
akl hat Folgendes geschrieben:
Nochmals die Bitte, Anregungen/Kommentare/Bugreports an die auf der Website hinterlegte eMail-Adresse zu senden - da ich hier im Thread nicht mitlese.
akl = Andreas Kleinert Wink
MINIAMIGA (4MB)
BeitragVerfasst am: So, 04.03.2007 11:14    Titel: Antworten mit Zitat
Ich werde heute mal die aktuelle Version installieren. Wink
[[OD|N]]
BeitragVerfasst am: So, 04.03.2007 13:00    Titel: Antworten mit Zitat
Hmm sind die eigentlich auch für User die SView Production Side haben und PPC nutzen ?
Oder nur für rein 68k User ?
A1200
BeitragVerfasst am: So, 16.09.2007 13:44    Titel: Antworten mit Zitat
Andreas Kleinert hat unbemerkt wieder kräftig geupdatet. Die Versionsstände sind vom 1.8.07 und 2.9.07. Danke Andreas!
link: http://www.ar-kleinert.de/download.html
@Odin
Zitat:
Just requires OS V3.1 and 68000, but also makes use of available
OS V3.5 and V3.9 features and 680x0 (030/040) module versions where
applicable. Some ELF modules for MorphOS are included as well.
Weitere Infos findest du in den ReadMes!
Zitat:
SV5Objects: - IFF-ACBM - Windows,OS/2 BMP - XPM v1-v3
- IFF-ILBM - JPEG (JFIF v6) - IMG (GEM/XIMG)
- IFF-DEEP - PhotoCD - WPG v5.0/v5.1
- IFF-FAXX - TIFF - MacPaint MAC
- IFF-PBM - PCX - EPS (Header/PS)
- IFF-RGB8 - PSD (Ph*t*sh*p) - Degas PI1-3/PC1-3
- IFF-RGBN - TIM - Spectrum ZX/SCR/TAP
- IFF-RGFX - XWD v11 - FBM
- IFF-YUVN - Windows Icon - CDR Preview
- QRT/POV Raytrace - Mac PICT v1/v2 - SGI
- SVG (SView) - Targa - Pictor/PCPaint
- SunRaster - RAW / RAW-CM - PNG
- CVP (passphoto) - Amiga Icons (lots) - SPP
- UtahRLE (RLE.5) - C64 GEOS - JPEG 2000 (JP2/PGX)
- C64 Koala - C64 Doodle - C64 GODOT/4BT
- PSP (PaintSh*p) - JPEG (LJPG) - Dr. Halo (CUT/PAL)
- PNM (P4-6) - PBM/PGM/PPM (P1-3) - XBM v10/v11
- MTV - MSP v1.0/v2.0 - HDR Radiance
- PFM HDR (Pf/PF) - NEO (r1-r3) - QL (QL4/Cool
- PXR (P*xar) - CT/SCT (Scitex) - WBMP (WAP)
- GIF 87a / 89a
interner Support nachstehender Module mittels externer Viewer wird es sogar noch viel mehr ... Das ReadMe ( http://www.ar-kleinert.de/data/SView5.readme ) lohnt sich.
huepper
BeitragVerfasst am: Mo, 12.11.2007 10:30    Titel: Antworten mit Zitat
Und wieder einmal hat Andreas eine neue Version ins Aminet gestellt.
Hierbei handelt es sich um Version 2.34 vom 10.11.2007.
ak hat Folgendes geschrieben:
Main changes since v2.33:
V2.34 (10.11.2007): (english)
- fixed layout of picture info requester (auth,anno,name,copy label position)
- text fields in picture info requester works with some file formats now
- file sub type display in picture info requester fixed (general)
- file sub type display in picture info works with some file formats now
- disabled some legacy code used for sview5.library versions < 5
- included sview5.library V14.11 (see there)
V14.1 (10.11.2007)
- too many to summarize (fixes in TIFF, EXIF support, upd. SVObject API)
Danke auch hierfür wieder an Andreas Kleinert. Wink
Und auch eine neue Datatypeversion ist erschienen.
Es handelt sich dabei um den aktiff.datatype in Version 45.80.
V45.80 (10.11.2007): - tiled images now are rejected
- unknown colorspaces now are
rejected (more often)
- added support for strips in
uncompressed 8 bit files
- fixed missing case in error
handling (unknown file type)
- now reports "object wrong type"
instead of "out of memory" in
case some file type cannot be
handled
MINIAMIGA (4MB)
BeitragVerfasst am: Sa, 29.12.2007 12:33    Titel: Antworten mit Zitat
Momentan ist Andreas sehr fleißig. Es gibt wieder Updates!
Zitat:
SView5 (ReadMe) SView5 (Download) v2.38 (27.12.2007)
akPNG (ReadMe) akPNG (Download) v45.83 (28.12.2007)
akJFIF (ReadMe) akJFIF (Download) v45.83 (28.12.2007)
akGIF (ReadMe) akGIF (Download) v45.83 (28.12.2007)
68k-Himmel! Danke!
BeitragVerfasst am: Di, 22.01.2008 07:43    Titel: Antworten mit Zitat
Sview 2.41 wurde am 20.01.08 released.
BeitragVerfasst am: So, 23.03.2008 10:58    Titel: Antworten mit Zitat
Version 2.50
Zitat:
V2.50 (21.3.2008): (english)
- Tools:
- WinSlide, ScrollSlide:
- fixed possible blitter race condition
- Plugins:
- ImageFX (Saver):
- updated spanish translations of many files
including the .guide again (base: v2.49)
(-> Damaso Dominguez)
- included sview5.library V15.11 (see there)
BeitragVerfasst am: Mo, 21.07.2008 07:11    Titel: Antworten mit Zitat
Zitat:
SView5 released in the Version 2.54 for Classic Amiga and MorphOS.
Changes:
- no longer tested under MOS 1.4.5;
increased requirements to MOS 2.0.0
- included sview5.library V15.15 (see there)
Quelle: AF
BeitragVerfasst am: Sa, 13.09.2008 11:47    Titel: Antworten mit Zitat
Zitat:
SView5 wurde in der Version 2.57 für Classic Amiga und MorphOS veröffentlicht.
Changes:
- General: - added new russian translation from Andrei Shestakov
- included sview5.library V15.18 (see there)
BeitragVerfasst am: Mo, 29.12.2008 12:10    Titel: Antworten mit Zitat
Link: http://aminet.net/package/gfx/misc/SView5
Ich hätte nie damit gerechnet, daß Andreas das Paket so fleißig weiterentwickelt. Für mich war das schn tot. Ein fettes Danke schön an Herrn Kleinert! Respekt.
BeitragVerfasst am: Mo, 16.02.2009 16:39    Titel: Antworten mit Zitat
Link: http://www.ar-kleinert.de/download.html V2.65 for Classic Amigas
Zitat:
Main changes since v2.62:
V2.65 (14.02.2009): (english)
- put OS4 support on my to-do list
- included sview5.library V16.7 (see history in SView5-Library Guide)
- see the first beta versions of SView5 for Windows (.NET)
on my website under http://www.ar-kleinert.de/sview5_win_e.html
the Win/Linux SDK will allow to be backported to AOS/MOS
(requires decent C++ SDK, thus a stable recent GCC version)
V2.64 (24.01.2009): (english)
- stack size now is automatically adjusted to the following minimum during
program start (regardless if Shell or WB) when necessary:
68K: 65K
MOS: 128K (tested)
OS4: 256K (let me know if it works)
If you still run into any troubles you may set a bigger value.
- included sview5.library V16.6 (see history in SView5-Library Guide)
- see the first alpha/beta versions of SView5 for Windows (.NET)
V2.63 (11.01.2009): (english)
- MOS support removed (no more .elf modules included)
- outdated translations removed
- spanish translation removed, so that Damaso can maintain
it separately on Aminet
- renamed download archive to "SView5-68k.lha" in order
to reflect the architecture change and reset the Aminet
download counter to something reasonable
- included sview5.library V16.5 (see history in SView5-Library Guide)
V16.7 (14.02.2009):
- Support-Lib: - controlpad code could have returned a non-NULL pointer
(in rare low-memory situations) when the original allocation
was already delocated; i.e. after a second alloc failed
- SV5Operators:
- Convolve: - default for "add" value now is 0
- this way the default matrix becomes "Blur"
- ConvolveNxN:
- default for "add" value now is 0;
default div value now equals matrix size
- ConvolveFloat:
- default for "add" value now is 0.0
V16.6 (24.01.2009):
- Docs: - cleaned up the "known problems" section
- SV5Drivers: - CgxOverlay: - now displays unaligned graphics properly
- SV5Operators: - ExtractGrayScales:
- fixed bogus config handling (sort order)
- AnyTo24Bit: - syntactic fixes
- AnyTo48Bit: - syntactic fixes (2x)
V16.5 (11.01.2009):
- Library: - outdated translations removed
- see the first alpha versions of SView5 for Windows (.NET)
using the Win/Linux C++ SDK based on SView5-Library
as described on http://www.ar-kleinert.de/index_pc_e.html
Auszug des ReadMes
